Hi~
I tried to promote with CYW43012
They(Customer) want to install CHIP for their own products.
Questions are like as below
Q1 : They want to CYW43012 as RTOS environments not based on OS(Linux)?
Is it possible to develop ?
Q2: If CYW43012 can be operated as standalone mode, It will be fit for their requirements.
Is it possible to be operated as stand alone mode?
Q3: If they want, they can chooose pick one method like as (WIFI only mode, BT Onlymode , WIFI & BT mode)?
Q4: If CYW43012 supports a stand-alone mode, It seems to communicate with SDIO interface and UART.
If then, They worried about the data transferring speed.
How fast can they transfer data?
Many Thanks
BRs
Daniel Lim
Q1. They want to CYW43012 as RTOS environments not based on OS(Linux)?
>> Yes, RTOS is supported with CYW43012. You can develop applications based on RTOS for CYW43012.
Q2. Is it possible to be operated as stand alone mode?
>> Please clarify what you mean. If you are asking about operating CYW43012 without host mcu then answer is no. The wifi applications will run on host mcu, so it cannot be operated stand alone.
Q3. If they want, they can chooose pick one method like as (WIFI only mode, BT Onlymode , WIFI & BT mode)?
>> Yes, it is possible to operate in all the mentioned modes using "WL_REG_ON", "BT_REG_ON" pins.
Q4. How fast can they transfer data?
>> Again, not sure what you mean by stand alone mode. CYW43012 can be interfaced with host mcu through SDIO interface. It supports SDR upto 50 MHz.
