I'm preparing to port CYW920706 to FreeRTOS and gathering information about this stuff from your community.
However, there is no docs for CYW20706 directly. I understand and do not expect there are every match cases between your chip and FreeRTOS. So, could you give me a general guide to port your wireless chip to FreeRTOS?
I can follow the way from FreeRTOS, but think the fastest way is following your recommendation.
Wireless
Hello SheetalJ,
I am using CYBT-343026-01 (which contains CYW20706). I was following an exercise 1: Blink an LED on pg20 in ch02 of this tutorial. The exercise uses CYW920819EVB-02 which I don't have.
At below location I cannot find the wiced_rtos.h.
mtb_shared\wiced_btsdk\dev-kit\baselib\20706A2\release-v3.1.0\COMPONENT_20706A2\include
Also, I could not find #include "cycfg.h" in mtb_shared directory.
Does CYW20706 support RTOS? How do I add these files to the project?
Hello @Da_Vinci
Wiced_rtos.h file is not available on CYW20706. RTOS APIs are not supported on 20706.
Anjana
Hello Anjana,
That means all the solution codes given in CypressAcademy_WBT101_Files tutorial will not work on CYBT-343026-01. Right?
Hi @Da_Vinci
Most of the examples on BLE & BR/EDR will be having almost same with respect to the stack event management etc.
But examples with RTOS APIs will not work on CYW20706.
Anjana
