- Email to a Friend
Dear Sir/Miss,
We used to use broadcom's BCM4356XKUBGT. And now there was a part number change when Cypress took over this series is CYW4356XKUBGT.
We want to know What is the P Code (IC version) Cypress IC corresponds to Broadcom BCM4356XKUBGT?Is it P32? If not, we may not be able to adopt it.
Your soonest reply will be highly appreciated!
- Email to a Friend
As per the internal team, we're not offering P code anymore since Cypress.
Aditi
- Email to a Friend
I'll check internally and revert back.
Aditi
- Email to a Friend
Aditi
- Email to a Friend
Thanks for your revert !
We used to try CYW4356XKUBGT on our boards months ago but it fails due to wrong OTP parameter to trigger WIFI over PCIe /BT over USB.we do not know what changes have been done of CYW4356XKUBGT even it is the same IC remarked from BCM4356XKUBGT or no P Code on CYW4356XKUBGT.We need to know how to configure the OTP parameters to trigger WIFI over PCIe /BT over USB on CYW4356XKUBGT if there is no P Code from Cypress.
- Email to a Friend
May I know how are you triggering WIFI over PCIe /BT over USB with the help of OTP parameters?
Aditi
