Is there an application note or reference software to interface CYW43012 based modules to MCUs?
Or more generally: What examples and application notes are available to support the effort required to connect Hosted radio modules to MCUs?
Examples in ModusToolbox appear to only address the Bluetooth side of CYW43012.
I found Application notes for single band WiFi modules. Are there similar Applications notes for dual band WiFi modules like CYW43012:
AN214941 - OTP Programming and NVRAM Development in SDIO Mode @ https://www.cypress.com/documentation/application-notes/an214941-otp-programming-and-nvram-developme...
AN214852 - Collaborative Coexistence Interface Between Cypress-to-Cypress Solutions and Cypress-to-third-party Chips @ https://www.cypress.com/documentation/application-notes/an214852-collaborative-coexistence-interface...
Oddly, links to the Evaluation Kit under "Design Tools" on the CYW43012 product page @ https://www.cypress.com/products/cyw43012 links directly to the sample request page and NOT to a description of the kit. I was expecting Examples and Application notes on the Evaluation kit webpage.
Note: There are some examples that appear to provide hints to creating a solution based on information that is available. Is a knowledge of an existing single mode product required before being able to attempt design using a dual mode product? Reference: STM32F469 porting in WICED @ https://community.cypress.com/t5/Resource-Library/STM32F469-porting-in-WICED/ta-p/246317
Wireless
Unfortunately, we don't have any reference material or application note that provides the guide on interfacing CYW43012 modules to MCUs. I'll surely take this as a feedback to the internal teams.
You can check out this link to do low power connectivity solution for IoT applications in case it helps.
Aditi
Aditi
