yolominwoo
25 replies posted 10 questions asked 25 sign-ins
When i porting my board(Nucleo745ziq+cyw43439) of wifi_join_wpa3
But i'm get a error code for 33555456 OTL....
How to solve my project..
I think the 'wifi' AP is not found the scan results. Only shown the  "_2.4G" and "KT_GiGA_" and "iptime".
Chuta_the_Cat
10 questions asked First like received 25 replies posted
Hi ,
The d'33555456 (=  0x200 0400) means the NETWORK NOT FOUND error.
whd_types.h describes as follows.#define WHD_NETWORK_NOT_FOUND WHD_RESULT_CREATE(1024) /**< Specified network was not found */
Could you please modify the correct AP name.
- Chuta_the_Cat
How to changed AP name?..?
Chuta_the_Cat
Hi ,
Please see the source code named "wifi_task.c" and change the two symbols
WIFI_SSID and WIFI_PASSWORD to adapt your AP infos.
/* Wi-Fi Connection related parameters */
#if !defined(WIFI_SSID)
#define WIFI_SSID "WIFI_SSID"
#endif /* (WIFI_SSID) */
#if !defined(WIFI_PASSWORD)
#define WIFI_PASSWORD "WIFI_PASSWORD"
#endif /* (WIFI_PASSWORD) */
- Chuta_the_Caat
I'm already chaged my ssid and password..
Chuta_the_Cat
Hmm ...
However the Tera Term snapshot  show that "***** Connecting to 'WIFI_SSID' AP *****" not "wifi" .
Could you also confirm the file location ?
Sorry, I'm posted before snapshot
Chuta_the_Cat
Can you try to do the "wifi_scan" project and get the your ’wifi' AP ?
Yes. wifi_scan was worked..
oh,, I'm sorry I known wifi join is mcu are host
I'm success connecting my wifi.
But, I'm defined WIFI_CONNECT_ENABLE
I'm get a same problem..
Anupam_K
50 sign-ins 5 solutions authored 10 replies posted
Kindly check the WIFI security protocol that is being used by the AP.
You can refer to https://infineon.github.io/wifi-host-driver/html/whd__types_8h.html#aaeeea5666743710aa4f01ff264b2705... to find the appropriate Wi-Fi security modes enum to use.
Anupam
Anupam_K
If  you are trying to connect with a WPA3 Personal you can set the WIFI_SECURITY (present below wifi password) in "wifi_task.c" to CY_WCM_SECURITY_WPA3_SAE.
Anupam
