Oct 05, 2021
07:06 PM
Oct 05, 2021
07:06 PM
I use "fqacurcy" command to set CYW4354 to transmit CW(continuous wave, non-modulated) signal, it works, but the CW signals are transmitted thru both Core0/Core1.
I tried to add "txchain" command to control it, but the CW signals are still transmitted thru both Cores.
How can I set it to transmit CW signal thru specified path?
Thanks for your help.
Frankie
Labels
- cyw4354
04:23 AM
Oct 26, 2021
04:23 AM
Hi @FrYa_4831451 ,
When using the CW mode testing the power is always maximum and cannot be change, the maximum power is set by the CLM.
