We try to test using SDIOv3 UHS-1(SDR104) mode.
It has supported this mode by SDIO Host controller.
However , We need to test using SDIO2.0 High Seppd Mode .
Does you have a good idea to force the Infineon 4373 to work in SDIO 2.0 High Speed mode?
Thanks,,
I think that there is way to modify the mmc driver for kernel.
Please apply this patch.
It will be disabled the SDIO 3.0 setting.
--- a/drivers/mmc/core/sdio.c
+++ a/drivers/mmc/core/sdio.c
@@ -148,6 +148,7 @@
card->scr.sda_spec3 = 0;
card->sw_caps.sd3_bus_mode = 0;
card->sw_caps.sd3_drv_type = 0;
+#if 0
if (cccr_vsn >= SDIO_CCCR_REV_3_00 && uhs) {
card->scr.sda_spec3 = 1;
ret = mmc_io_rw_direct(card, 0, 0,
@@ -181,6 +182,7 @@
if (data & SDIO_DRIVE_SDTD)
card->sw_caps.sd3_drv_type |= SD_DRIVER_TYPE_D;
+#endif
/* if no uhs mode ensure we check for high speed */
if (!card->sw_caps.sd3_bus_mode) {
This patch is for Linux Kernel 5.4.
@@ -148,6 +148,7 @@
+#if 0
@@ -181,6 +182,7 @@
+#endif
