I'm trying to make a custom bootloader with Wiced for CYW43907.
The aim is to implement a custom implementation of direct firmware update.
I based it on waf/ota2_bootloader.For the uart I'm using platform_stdio with WICED_UART_1, /* ChipCommon Slow UART */
It's built as roomz.custom_bootloader-NoOS-NoNS-CYW943907AEVAL1F JTAG=jlink VERBOSE=1 download_apps download
So far it's compiling, linking, programming, starting and printing to uart. Which is already nice : )
I'm having troubles with reading uart , and I do not understand how the platform_stdio.c shall work.
- Can you explain to me how the stdio_tx_mutex works? Where is it set?
- Is there an implementation of semaphore which handles timeouts ? In Wiced/rtos/NoOS/WWD/wwd_rtos.c the timeout is ignored.
Current implementation flash/ram usage:
Module | Flash | Static RAM |
App | 0 | 66220 |
Interrupt Vectors | 0 | 296 |
libc | 0 | 33504 |
NoOS | 0 | 776 |
Other | 0 | 17340 |
platform | 0 | 444 |
RAM Initialisation | 32 | 0 |
Ring_Buffer | 0 | 132 |
Startup Stack & Link Script fill | 0 | 56 |
WWD | 0 | 248 |
TOTAL (bytes) | 0 | 119016 |
I can provide the project in private message if needed.
ispn:36623:1:0
l1:3966:1:0
l2:6066:1:0
Hi @cedric_roomz ,
Can you please refer to the example code present in wiced/apps/snip/uart .
Basically both the methods should work. We can check your code if it is not solving your problem.
you may have to ring buffer to receive the data through UART and the API to receive is wiced_uart_receive_bytes.
Rakesh B G
So now I've removed the platform_stdio and use platform_uart_ instead.
The write still works fine. But I cannot make the read work.
- Shall the uart read works with UART_SLOW and NoOS?
- Shall I use BCM4390X_UART_SLOW_POLL_MODE or normal mode?
Hi @cedric_roomz ,
Rakesh B G
