CY8CKIT-062S2-43012 having a chip antenna, is there anyway I can do Conducted RF tests on CYW43012 in CY8CKIT-062S2-43012.
How can I do conducted RF tests like RX sensitivity, ACR etc. on CY8CKIT-062S2-43012. Is there any modification I could make to do conducted RF tests on the chip.
Arun Varghese
Hi @arun1 :
If you want to do conducted RF test, you should modify the PCBA by yourself.
You should move C49 to C50 and solder a IPX connector on J1, and then you can connect RF cable with it.
Colin
Hi @arun1 :
Colin
Hi @arun1 :
You can find the documents of EVB from below:
https://www.infineon.com/cms/en/product/evaluation-boards/cy8ckit-062s2-43012/#!designsupport
Colin
