AIROC™ Wi-Fi and Wi-Fi Bluetooth Combos Forum Discussions
Rabbit
I try to start WiFi application project, but I'm new to Cypress MCU.
There are two DevKit:
CY8CKIT-062-WIFI-BT, it is too expensive.
CY8CPROTO-062-4343W, price is good, but I check the user manual, no place for WiFi antenna,
how to make this DevKit for  WiFi prototype?
Qi_Colin
250 sign-ins 50 solutions authored 25 likes received
Hi @Rabbit :
If you don't require LCD on your prototype, I suggest you use CY8CPROTO-062-4343W.
I'm not sure the meaning of no place for WiFi antenna.
Is that means no external connector for WiFi antenna?
If so, CY8CPROTO-062-4343W can support external antenna.
You can check the schematic of the WiFi module.
Colin
Qi_Colin
Hi @Rabbit :
Colin
Hi Colin,
Thanks for your information, I can view the antenna is "A1".
Rabbit
