AIROC™ Wi-Fi and Wi-Fi Bluetooth Combos Forum Discussions
Yahya_Yozo
First like given First reply posted First question asked
Hi Guys,
I will be working on the Laird Sterling LWB5+ module which is based on CYW4373 chip
I want to configure to create an access point so I can connect to using my smartphone
I want to know if this module supports creating WI-FI access points, also please provide me with corresponding documents / datasheets /user manual that can help me
Big thanks
Rakesh_BG
Moderator 10 likes received 25 solutions authored 50 replies posted
Hi @Yahya_Yozo ,
The direct example code for access point is not available but it is achievable using the API's available. Basically refer that document and setup things for wifi scan and then you can go for access point implementation.
Rakesh B G
Vivek_gunapati
Moderator 10 likes received 25 solutions authored 100 replies posted
Hi @Yahya_Yozo, To help me understand your setup could you please let us know the following
-> Could you please let us know if you are using a Microcontroller or a Linux microprocessor to communicate with the CYW4373?
Vivek
Yahya_Yozo
I'll be using an STM32 MCU to communicate with CYW4373
Rakesh_BG
Hi @Yahya_Yozo ,
You can use stm32 connectivity expansion pack to achieve the requirement.
The link for user guide is attached.
https://github.com/Infineon/stm32-connectivity/blob/master/Documentation/STM32ConnectivityExpansionP...
Rakesh B G
Yahya_Yozo
This guide shows an example of a Wi-Fi scan for the available access point , I want the opposite, I want the module to create an access point ?
Is this doable ?
Yahya_Yozo
Please provide me with the documents / datasheets /user manuals that can help me, thanks
Rakesh_BG
Hi @Yahya_Yozo ,
Rakesh B G
