I'm starting to develop a custom bootloader which will be able to receive a firmware over uart and write it on flash. I've started from the tiny_bootloader provided in the wiced example and have integrated the sflash_write example and the uart driver.
For now I'm having issue during link, it does not find all variables which shall be provided by the linker: undefined reference to `link_aon_data_location' 'link_aon_data_end' 'link_ram_data_location'
See build output:
"C:\\workspace\\wiced\\WICED-Studio-6.6\\43xxx_Wi-Fi\\make.exe" roomz.custom_bootloader-CYW943907AEVAL1F JTAG=jlink download run
MAKEFILE MAKECMDGOALS=roomz.custom_bootloader-CYW943907AEVAL1F download run OTA2_SUPPORT is disabled
Building Bootloader waf.bootloader-NoOS-NoNS-CYW943907AEVAL1F-P103-SoC.43909
Building Serial Flash Loader App
prgm hdr cnt=3
total_size = 15920, entry_point = 0x696000
Loadsegment_offset = 0xA0 segment_size = 15684, segment_pad = 0
Loadsegment_offset = 0x3DF0 segment_size = 32, segment_pad = 0
Loadsegment_offset = 0x3E14 segment_size = 204, segment_pad = 0
Finished Building Bootloader
Finished Building Serial Flash Loader App
Making roomz.custom_bootloader-CYW943907AEVAL1F.elf
build/roomz.custom_bootloader-CYW943907AEVAL1F/Modules/apps/roomz/custom_bootloader/roomz_bootloader.o: In function `load_app':
C:\workspace\wiced\WICED-Studio-6.6\43xxx_Wi-Fi/apps/roomz/custom_bootloader/roomz_bootloader.c:140: undefined reference to `link_aon_data_location'
C:\workspace\wiced\WICED-Studio-6.6\43xxx_Wi-Fi/apps/roomz/custom_bootloader/roomz_bootloader.c:140: undefined reference to `link_aon_data_end'
tools/makefiles/wiced_elf.mk:315: recipe for target 'build/roomz.custom_bootloader-CYW943907AEVAL1F/binary/roomz.custom_bootloader-CYW943907AEVAL1F.elf' failed
C:\workspace\wiced\WICED-Studio-6.6\43xxx_Wi-Fi/apps/roomz/custom_bootloader/roomz_bootloader.c:140: undefined reference to `link_ram_data_location'
collect2.exe: error: ld returned 1 exit status
make.exe[1]: *** [build/roomz.custom_bootloader-CYW943907AEVAL1F/binary/roomz.custom_bootloader-CYW943907AEVAL1F.elf] Error 1
make: *** [main_app] Error 2
Makefile:351: recipe for target 'main_app' failed
However those variables seems to be present in the map file in 43xxx_Wi-Fi\build\roomz.custom_bootloader-CYW943907AEVAL1F\binary\roomz.custom_bootloader-CYW943907AEVAL1F.map
Any idea why the linker does not find them?
After some digging I found that there is some magic which chose the link command using the app name in:
\\Desktop-gqohcdq\c\workspace\wiced\WICED-Studio-6.6\43xxx_Wi-Fi\WICED\platform\MCU\BCM4390x\BCM4390x.mk
Now I find that the bootloader does (unsurprisingly) not fit the 8KB AON ram.
c:/workspace/wiced/wiced-studio-6.6/43xxx_wi-fi/tools/arm_gnu/win32/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld.exe: build/roomz.custom_bootloader-CYW943907AEVAL1F/binary/roomz.custom_bootloader-CYW943907AEVAL1F.elf section `.text' will not fit in region `AONRAM'
c:/workspace/wiced/wiced-studio-6.6/43xxx_wi-fi/tools/arm_gnu/win32/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/bin/ld.exe: region `AONRAM' overflowed by 25532 bytes
Is it possible to put my custom bootloader in "normal" RAM ?
What all changes have you done to implement the custom bootloader? Can you provide an approximate idea of how much memory space this bootloader is consuming?
Aditi
