CYW4373E - Regarding RF_SW_CTRL5
MiSa_2357281
Distributor - Macnica (Japan)
5 replies posted 250 sign-ins First solution authored
Hello all
Can you give me more details about the RF_SW_CTRL5 pin? Also, what should I do if I don't use it?
Thanks,,
KeOn_
100 sign-ins 25 replies posted 10 solutions authored
Used as an antenna switch control pin when implementing a diversity antenna.
Leave this pin floating if you do not use a diversity antenna.
KeOn_
