If the CYW4373E firmware hang-up for some reason (such as a security attack), is there a way to know the status?
Also, if there is a procedure to initialize the CYW4373E when the CYW4373E hang-up, please let me know.
Thank you.
Could you please specify the issue you are facing?
CYW4373E is getting hanged while configuring Wifi/BT?
Tushar
There are no issues currently facing.
I asked this question because I want to know how it behaves when it is hang-up after it goes on the market.
Thank you very much.
How is the progress on the above question?
KeOn_
We didn't encountered any issues related with firmware hang, however there may be issues related with corrupt .hcd file which may hang i.e while loading the firmware or BT FW gets hang if WLAN send interrupt before BT initialize process is not completed.
However, please do reach out if you face any issues related with it.
Tushar
