Nov 20, 2022
07:30 PM
Nov 20, 2022
07:30 PM
Does the transmission power control function (TPC) work in station mode?
If it works, please tell me under what conditions (procedures) the transmission power will drop by 3 dB.
- cyw4373
01:00 AM
Nov 30, 2022
01:00 AM
10:20 PM
Nov 21, 2022
10:20 PM
Hi
The TPC works in the STA mode if it is enabled in the firmware.
Regarding the condition - I will check and get back to you.
07:36 PM
Nov 28, 2022
07:36 PM
Thank you for your reply.
I have an additional question.
Is the TPC function enabled in the FW included in cypress-fmac-v5.10.9-2022_0511?
Also, is there a wl command that can confirm that the TPC function is enabled?
Thank you very much.
Nov 30, 2022
01:00 AM
Nov 30, 2022
01:00 AM
Yes, TPC is enabled in the firmware.
