Hi team,
我们的gps接收机产品集成了使用 CYW43455的murata的模块LBEE5HY1MW-230 ;目前我们产品在做CE认证时需要固定wifi 频段,请帮忙分享下wifi测试指令集,谢谢!
Hi zhang,
Debugging status, unable to recognize wl instruction,Help confirm,thanks a lot
hello:
What is your OS and CPU ARCH like Linux /ARM? Typically, you will get the mfg firmware and wl tool from FAE or Distributors.
Hi zhang,
OS and CPU ARCH is Linux imx6ull&arm,Look forward to your reply.
hello,
How to rename?We don't know how to use this tool.
try to push the wl tool into your system"
use a udisk and plug it into your imx6.
mv wl6 /usr/bin/wl
cd /usr/bin/
chmod 777 wl
then try to input the command:
wl ver
hello,
We are done the tool import,but still command not found (43455__TEST_COMMAND.zip)
Can you use ./wl in the directory?
FYI,Please help to confirm,tks
you need to rename wl6 to wl in the first place:
mv wl6 wl
then use the command:
./wl ver
Hi ,
We can't rename wl6
ok, just run wl6 directly
./wl6 ver
Permission denied,Please help
hello:
you need to input:
chmod 777 wl6
Help see it again,tks!
ok, please input ./wl6 -h to see if the tool can run well.
then please insmod driver in the first place.
Do you know the difference between mfg and normal firmware?
It is better to add module maker support resources to your team, it is not an efficient way to have all the support from the forum.
Thank you for your support; input ./wl6 -h can run well,
the difference between mfg and normal firmware?--Help explain
Our trouble is Murata cannot provide local support。
sure, so the tool can run well.
you need to open wifi function, then try to use ./wl6 ver
to check if the firmware has TEST string ..
You can ask them to provide MFG firmware, MFG firmware is used for RF tests, and manufactory tests.
if you use normal firmware, some commands can't be used.
Thanks a lot, ./wl6 still can not found,
We asked Murata to provide the mfg firmware and try again。
attached have two files, which one to use;Put it in the wl file, right?
you can rename them to wl in windows environment, then push them to a directory, and have a try with both files.
hello:
Would you please tell me if any other support is needed?
hello:
if no more updates, I will resolve this thread, other requests can be raised with a new thread!
OK,thanks!
