DCW-L
10 sign-ins First like received First reply posted
Dear everyone
We are trying to use the CYW43455 device to connect different AP.
First device we use Synology MR2200ac (WPA3), it connected successfully.
But when we use D-Link DIR-842 C1 which is having ImmortalWrt 23.05.1 firmware (WPA3), it can not be connected.
Does anyone have ever use CYW43455 device to connect the ImmortalWrt setting AP ?
Or can CYW43455 communicate to Immortal system?
Thank you.
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
Hello:
   it is better to have a supplicant log and sniffer log to figure out the reason.
Dear Zhengbao
Please refer to attached file.
The file is included immortal SSID information and logs.
Thanks for your reply and help!
Zhengbao_Zhang
hello:
 the log shows the D-linkIn AP is a WPA3-R3 version, did you ever add sae_pwe=2 into the wpa_supplicant.conf ?
