Hi~
Our customer developed WIFI &BT Combo module.
They want to fix some channel to increase connection speed for AP.
They tried to change channel table like as below.
freq_list=5745 5765
network={
ssid="KMH_AP_5G"
psk="1qaz2wsx"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP
group=CCMP TKIP
auth_alg=OPEN
scan_freq=5745 5765
But It doesn't seem to work properly.
Is there any method to solve that issue?
Thanks alot
BRs
Daniel Lim
You are bringing up SoftAP and want to fix a channel on which AP operates. Is that right?
You can specify the channel while bringing up AP itself. Is your setup Linux or RTOS based?
In ModusToolbox, you can set the channel you want using the "channel" member of "cy_wcm_ap_config_t" structure like below.
cy_wcm_ap_config_t ap_conf;
ap_conf.channel = 1;
Hi~ PRI
No, I don't want to bring up SoftAP.
Because our project move so fast. So, I want to reduce connection time to connect next AP.
I think if I make a limitation of the connection channel bands, I can connect other AP quicklier than before.
I developed it based on Linux.
Main MCU is NXP.
Hi Daniel,
Sorry but still I don't fully understand your setup and requirement. What is that channel table you mentioned in your first post? Are you using FMAC or WHD driver?
You want your STA to scan a particular channel for the specified AP to join rather than scanning all the channels, is it?
