AIROC™ Wi-Fi and Wi-Fi Bluetooth Combos Forum Discussions
FrYa_4831451
25 sign-ins 5 questions asked 5 replies posted
Hi Infineon,
Does CYW43439 support WPA3-Personal in SoftAP mode by linux FMAC driver?
Frankie
Vivek_gunapati
Moderator 10 likes received 25 solutions authored 100 replies posted
Hi @FrYa_4831451 , Yes the latest driver and firmware available in the link -> https://community.infineon.com/t5/Wi-Fi-Bluetooth-for-Linux/Cypress-Linux-WiFi-Driver-Release-FMAC-2... supports the WPA3-R3 in SoftAp mode.
Hope
This helps
Vivek.
Vivek_gunapati
Hi @FrYa_4831451 ,
WPA3-Personal in SoftAp is supported in the current release of the driver and firmware (https://community.infineon.com/t5/Wi-Fi-Bluetooth-for-Linux/Cypress-Linux-WiFi-Driver-Release-FMAC-2...
However the hostapd.conf needs to be configured w.r.t WPA3, below is a sample hostapd.conf to get started with wpa3
interface=wlan0
driver=nl80211
ctrl_interface=/tmp/hostapd
ssid=wpa3_ap
hw_mode=g
channel=1
macaddr_acl=0
auth_algs=1
wpa=2
wpa_key_mgmt=SAE
wpa_passphrase=test_ssid
rsn_pairwise=CCMP
wpa_pairwise=CCMP
ieee80211w=2
Vivek.
FrYa_4831451
Hi Infineon,
Thanks for your reply, according to that WPA3 was updated to R3 version for WFA certification, could you help to advise the driver and firmware are supported to pass WPA3-R3 in SoftAP mode.
Frankie
Vivek_gunapati
Hope
This helps
Vivek.
