We're evaluating the CYW43439. So far WiFi is working great with wifi_host_driver. However, due to pin count restrictions we would like to use Bluetooth through gSPI instead of UART. The datasheet and WHD code say gSPI function 3 is for bluetooth, so it seems this should be possible?
The WHD code has support for plugging in a bluetooth device, and for calling a callback on it on interrupt: https://github.com/Infineon/wifi-host-driver/blob/master/WiFi_Host_Driver/src/bus_protocols/whd_bus_... . However I haven't seen any code to actually use this. Is it available somewhere? Or is there some documentation on how to do it?
Thank you!
The gspi is for wifi usage. For Bluetooth, you can only use the UART interface.
