Hello All,
We need to add CYW43439 driver in Linux kernel 3.2 on Phycore AM335x board.
Is there any CYW43439 driver available supported in Linux kernel 3.2?
If not where can I get the latest driver and what are the changes required to support this driver in kernel 3.2?
Prathamesh Kulkarni
Hi @prathamesh ,
The latest driver can be downloaded from the following link -> https://community.infineon.com/t5/Wi-Fi-Bluetooth-for-Linux/Cypress-Linux-WiFi-Driver-Release-FMAC-2...
From the README file of the latest driver, the FMAC driver backports support from V3.10+ to v5.15.58
We do not support Linux kernel < v3.10
Vivek.
Hi @Vivek_gunapati ,
Thanks for sharing your inputs.
If we want to add this driver in Linux kernel 3.2, what are the changes we should make?
Prathamesh Kulkarni
HI @prathamesh,
We don't have a guide on the changes needed to work with kernel 3.2. However manual porting is required to replace the latest APIs with older APIs etc.. and also please note that all the functional tests are tested and verified on kernels greater than v3.10+ so if there are any issues with kernel 3.2 we may not be able to support fully.
Vivek.
Hi @prathamesh ,
Yes FMAC is supported on the arm core running Linux
Since most of the questions are answered please let us know if we can close the issue?
