CYW43438 SoftAP seems unstable
LeonH
Level 4
Level 4
Distributor - Arrow(GC)
100 sign-ins First solution authored 50 sign-ins
Hi Sir,
We use CYW43438 as softAP with dhd driver, and use smart phone as client, and their distance around 5m.
Firmware version: bcm43438-7.46.58.11
While doing ipef throughput test, throughput will keep 1x Mbps around several seconds in channel 1 or 11, then down to 0 Mbps.
We have to disconnect and re-connect for recovery.
For same test in channel 6, it seems testing good, but only keep normal around several minutes.
What could we do to keep throughput test stability in AP mode?
Vivek_gunapati
250 replies posted 10 likes given 50 solutions authored
Hi @LeonH ,
This request cannot be supported on the Community and request you to raise a support ticket, For more details on this please contact the Infineon sales team.
Vivek
Vivek_gunapati
Hi @LeonH ,
Vivek
Hi @LeonH, we see that you have raised a support ticket. Could you please let us know if we could close the community post?
LeonH
Level 4
Level 4
Hi Vivek,
Yes, thank you.
