I am currently using WICED-Studio 6.2.
I checked the GPIO combination that can be CYW20706.
The "spiffydriver.h" file does not contain any GPIOs currently available.
I would like to use SLAVE1_P02_CS_P24_CLK_P38_MOSI_P25_MISO=0x02182619
Is there a way to use it?
Hello @munjr0612_48795
P24 is internally used for some other functionality. I am not sure if this Pin combination will work or not.
The pins which I tested and verified is available in the blog here: https://community.infineon.com/t5/Resource-Library/SPI-example-for-CYW20706/ta-p/246403
Can you try using those pins?
Anjana
Anjana
