CLM Regulatory RF output power setting and verification
FrYa_4831451
Distributor - Weikeng(GC)
First like given 10 questions asked 10 replies posted
I used 43455 module for our design, and the nvram is provided by module maker.
I want to set the RF output power thru CLM Regulatory procedure, and I know that I have to fill the Regulatory template to request for new clm_blob creating.
1) Assumed I want to set 10dBm Conducted power for 2.4GHz/11b/all rates at module pinout, does it mean that I just need to fill "10dBm" into the "Target Power" field and select Conducted at "Measured" field?
2) Once I get the new clm_blob file, I will use "wl curpower" to verfiy the setting. Does it mean that I will see the "10dBm" setting at "Power Targets", and I can get the "10dBm" at "Power Target for current rate" if I set the correct rate?
Frankie
YashM
50 solutions authored First question asked 250 sign-ins
Hello
We don't provide custom clm_blobs on the community.
Please refer to the following training link for more information regarding the same Introduction to Infineon's Wi-Fi Regulatory flow
YashM
Hello
