Hi Infineon,
Is it possible to run AP(5GHz)+STA(5GHz) in RSDB mode on CYW54591? Can I set the different channel but both of chains are running in 5GHz band, I expect to use this condition to maximize the throughput while RSDB mode is enable.
Thanks and regards.
Frankie
Hi @FrYa_4831451, Thank your query,
Currently in CYW54591, it is possible to create AP(5GHz)+STA(5GHz) in the same channel, different channel is not possible. The AP and STA needs to be in the same channel. If the STA (5GHz) is connected to an AP in channel 38 . then AP(5GHz) that is brought up in 5GHz will be forced to set its channel as STA-5GHz-channel i.e 38.
Vivek.
Vivek.
