- Email to a Friend
Does anyone know where I can find the JTAG BSDL file for the CYW43438 please?
Many thanks,
Matt
- Email to a Friend
Hi @MattN101 :
Thank you for your query.
We don't have the BSDL file for CYW43438 can be provided.
May I know the reason why you need the BSDL file?
Colin
- Email to a Friend
Hi Colin, thanks for your reply.
We're trying to set up a boundary scan chain to test several BGA devices on one of our PCBs. I'm new to JTAG but I believe the BSDL file is required as it contains the boundary scan information for the IC under test. The datasheet states that the CYW43438 supports boundary scan over SDIO, I'm not sure how to use this without a BSDL file.
Do you have any ideas?
Kind regards,
Matt
- Email to a Friend
Hi @MattN101 :
For this issue, I suggest you to contact our infineon local sales team or FAE team to build a case for individual support.
Colin
- Email to a Friend
Hi @MattN101 :
I‘ve seen that you got the support from our case system, so I will close this thread.
Colin
