I'm taking into consideration to use Cypress CYW43455 that integrated in LBEE5HY1MW module.
Our technologies use BT5.0 and need to communicate with this module as Client.
I have found the attached spec, and still have some questions related the BT Low Energy spec.
- Does this module support Long Range mode ? primary Coded phy ?
- What is the sensitivity of the BT transceiver?
- What is the maximum power gain of the antenna? could it transmit in 8dbm ? what are the ranges ?
- Is there a available detailed datasheet that I can read about it?
