FeTa_4356966
Distributor - Zenitron(GC)
50 sign-ins 10 likes given 25 sign-ins
[AzureWave AW-CM390SM(CYW43455)] Security Erratum 11838 required for BQB certification
BQB certification laboratory needs me to provide "Erratum 11838"report. Is there a test report issued by Ellisys?
Or is there a newer version of CYW43455 QDID for direct application?
Zhengbao_Zhang
250 sign-ins First comment on KBA 10 questions asked
Hello:
    I can't commit it here,  A reach to marketing person is a better way if it is in a hurry and needs a confirmed date.
Zhengbao_Zhang
Hello:
    Would you please raise help to module maker also? I think they should have this kind of documents for BQB tests .
FeTa_4356966
AzureWave AW-CM390SM has not yet applied for BQB certification.
Zhengbao_Zhang
ok, it is better to ask them to get the file through another issue system, I think it is not suitable to release the files on community.
FeTa_4356966
Need to use MY CASE? or EMAIL?
FeTa_4356966
Will the DID of CYW43455 be updated recently?
Or how to make the product pass BQB?
Zhengbao_Zhang
Hello:
   I will try to find one DID for 43455, for how to pass BQB, I think the process is:
1.  send the product to a veirified third-party organiztion.
2.  using some tools to do signal or non-signal tests to get the certification.
FeTa_4356966
Okay, waiting for your response.
Zhengbao_Zhang
hello:
   You can get the info from this link:
https://launchstudio.bluetooth.com/ListingDetails/72609
FeTa_4356966
Yes, I found DID: D040197/Listing Date: 2018-11-13 at the beginning, and the lab asked us to supplement the report.
It may be that the date is relatively old and the report needs to be supplemented.
BQB certification lab needs me to provide "Erratum 11838"report. Is there a test report issued by Ellisys?
Release Adopted Date Notes
Erratum 11838 13 August 2019 Mandatory when claiming compliance to Bluetooth Core Specification v4.2 to v5.1
https://www.bluetooth.com/specifications/errata/
FeTa_4356966
Is there a solution? Or can you tell me when the new version of QDID will be updated?
Zhengbao_Zhang
Hello:
FeTa_4356966
OK, TKS!~😀
