[AzureWave AW-CM390SM(CYW43455)] Security Erratum 11838 required for BQB certification
BQB certification laboratory needs me to provide "Erratum 11838"report. Is there a test report issued by Ellisys?
Or is there a newer version of CYW43455 QDID for direct application?
Hello:
I can't commit it here, A reach to marketing person is a better way if it is in a hurry and needs a confirmed date.
Hello:
Would you please raise help to module maker also? I think they should have this kind of documents for BQB tests .
AzureWave AW-CM390SM has not yet applied for BQB certification.
ok, it is better to ask them to get the file through another issue system, I think it is not suitable to release the files on community.
Need to use MY CASE? or EMAIL?
Will the DID of CYW43455 be updated recently?
Or how to make the product pass BQB?
Hello:
I will try to find one DID for 43455, for how to pass BQB, I think the process is:
1. send the product to a veirified third-party organiztion.
2. using some tools to do signal or non-signal tests to get the certification.
Okay, waiting for your response.
Yes, I found DID: D040197/Listing Date: 2018-11-13 at the beginning, and the lab asked us to supplement the report.
It may be that the date is relatively old and the report needs to be supplemented.
BQB certification lab needs me to provide "Erratum 11838"report. Is there a test report issued by Ellisys?
Release | Adopted Date | Notes |
Erratum 11838 | 13 August 2019 | Mandatory when claiming compliance to Bluetooth Core Specification v4.2 to v5.1 |
Is there a solution? Or can you tell me when the new version of QDID will be updated?
Hello:
OK, TKS!~😀
