Hi sir,
Because using CYW43455 for BQB certification, need to provide "Host QDID". My system is Embedded Linux and uses BlueZ 5.0 Stack. Can the following be used?
QDID 172247
https://launchstudio.bluetooth.com/ListingDetails/134246
Wireless
QDID 172247 is certified to AIROC™ Bluetooth Host Software Stack.
Since you are using your own BlueZ 5.0 Stack, then your device won't be using AIROC™ Bluetooth Host Software Stack. The CYW43455 merely acts as a controller. So you need to provide the QDID of your BlueZ 5.0 Stack (which I think you should get certified by yourself).
Because BlueZ Stack certification takes too much time, can I directly use WICED or BSA QDID?
CY-WICED 4.1 BLUETOOTH Host Stack
QDID 160340
https://launchstudio.bluetooth.com/ListingDetails/120227
CYW-BSA50
QDID 137661
Since you are using your own BlueZ 5.0 Stack, then your device won't be using any other Bluetooth host stack. So any other stack's QDID won't be suitable here.
