Are you facing any issues in porting the library or do you need a reference port done here?
Hello, Thanks for your quick reply. I have found a community thread( Using-the-CMSIS-DSP-Library-in-a-ModusToolbox)which talks about using CMSIS with Modus Toolbox. Got the CMSIS-DSP sources from here: GitHub - ARM-software/CMSIS_5: CMSIS Version 5 Development Repository. Need help in compiling and linking the DSP source to the project through WICED IDE.
