When I perform WPS with the library "wiced_wps_enrollee ()" of WICED-Studio-5.0, the code "3004" (PBC OVERLAP) is returned and WPS fails.
It occurs only when the wireless router (Buffalo: WTR M2133HP) is opposed to the confirmed range.
Could you please tell me the cause or possibility of this event?
// In Japanese.
WICED-Studio-5.0のライブラリ"wiced_wps_enrollee()"でWPSを行った際、"3004"(PBC OVERLAP)というコードが返ってきてWPSが失敗します。
確認出来た範囲で、無線ルータ(Buffalo製:WTR M2133HP)対向の場合のみ発生します。
本事象の発生原因或いは、可能性を教えて頂けませんか?
Wireless
- wiced_wps_enrollee
Yea, WinUSB will work as it's a generic USB driver provided by Microsoft. For your API related query, do you need this specific API in your application?
Aditi
Hi, Aditi-san.
Thank you for your comment.
I'm sorry, we don't have an environment to run WICED_6.6, so it's difficult to check with WICED_6.6.
Is it possible that WICED_6.6 will resolve this issue?
Is there a difference in WPS functionality between WICED_5.0 and WICED_6.6?
Best regards.
The latest versions of WICED usually comes with some fixes to the problems that we might face in the older versions. So, it's usually good to check your use case in 6.6 as WICED 5.0 is pretty old version. Also, it might help us to isolate the issue.
Aditi
Sorry for late response.
I'm currently trying to upgrade to the latest version.
However, the following error occurs and the download cannot be performed.
Do you know where the problem is?
Creating Filesystem BCM94390x_targets.mk ...
Downloading DCT ... build/fg_apt-BCM943907WCD2/DCT.bin @ SFLASH_DCT_LOC=0x00008000
./tools/common/Win32/mk_wicedfs32 build/fg_apt-BCM943907WCD2/filesystem.bin build/fg_apt-BCM943907WCD2/resources/Staging/
Creating Filesystem Done
WICED/platform/MCU/BCM4390x/BCM94390x_targets.mk:395: recipe for target 'download_dct' failed
make.exe[1]: *** [download_dct] Error 1
Makefile:351: recipe for target 'main_app' failed
make: *** [main_app] Error 2
Best regards.
Can you provide your make target that you're using for the build?
Aditi
Additional information.
There was evidence of an error in openocd_log.
Do you know how to avoid the error?
(This error does not occur in WICED 5.0.)
<\WICED-Studio-6.6\43xxx_Wi-Fi\build\openocd_log.txt>
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
trst_and_srst separate srst_gates_jtag trst_push_pull srst_open_drain connect_deassert_srst
trst_and_srst separate srst_nogate trst_push_pull srst_open_drain connect_assert_srst
adapter speed: 100 kHz
adapter_nsrst_delay: 100
Info : auto-selecting first available session transport "jtag". To override use 'transport select <transport>'.
jtag_ntrst_delay: 100
post_init_psoc6_setup
Error: libusb_open() failed with LIBUSB_ERROR_ACCESS
Error: no device found
Error: unable to open ftdi device with vid 15ba, pid 002a, description 'Olimex OpenOCD JTAG ARM-USB-TINY-H', serial '*' at bus location '*'
Best Regards.
After replacing the OLIMEX-ARM-USB-TINY-H driver with WinUSB(by zadig), I was able to download it.
Is this corrective?
And I have another question.
I think some APIs have been removed between WICED 5.0 and WICED 6.6. (For example, "wiced_pwm_set_duty_cycle ()")
Is there a way to think of these alternatives?
Best regards.
Aditi
