I am trying out this cyw43907 example https://github.com/Infineon/mtb-example-cyw43907-tcp-client
Have a CYW43907AEEVAL1F board.
lsusb shows it as ..
Bus 020 Device 039: ID 0a5c:43fa Broadcom Corp. WICED Eval Board
I am trying to program the board and running into this error.
Programming target device...
Open On-Chip Debugger 0.11.0+dev-4.3.0.1746 (2021-09-16-15:53)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
trst_and_srst separate srst_nogate trst_push_pull srst_open_drain connect_assert_srst
adapter speed: 100 kHz
adapter srst delay: 10
jtag_ntrst_delay: 10
Error: no device found
Error: unable to open ftdi device with vid 04b4, pid f900, description '*', serial '*' at bus location '*'
** OpenOCD init failed **
shutdown command invoked
make[1]: *** [qprogram] Error 1
make: *** [secondstage_build] Error 2
I am wondering whether this error is because I have an old verion os CYW43907AEEVAL board?
ispn:36623:1:0
l1:3966:1:0
l2:6066:1:0
Might be a possibility. I just tried this CE on a CYW943907AEVAL1F and download goes through fine and application runs without any issues. But I'm running this on Windows and given that you are saying 'lsusb' I pressume that you're on a linux machine. Can you try this on a Windows machine so that we can figure out if the issue is with the software or the 907 Eval board?
