importance of DHCP server in WHD
aniruddhann
25 sign-ins 10 sign-ins 5 questions asked
Hi, I am evaluating a WiFi feature with CYW4343, using WHD driver. I see a DHCP server implemented there. And, I take it to provide IP to the station nodes (when the Host is acting as AP). correct ? Basically, the zephyr framework does not have DHCP server implemented, so temporarily, will it work if a particular IP is assigned. or any workaround to skip DHCP server implementation ? any suggestions.
@aniruddhann
Phanindra_I
250 sign-ins 10 likes given 25 likes received
Yes, the DHCP server assigns IP addresses to the station nodes. DHCP server is implemented in wifi-mw-core library, not in WHD. When you have multiple stations connected to AP then DHCP server dynamically assigns IP addresses but If it's just one station, I believe it will work by assigning a particular IP address.
Phanindra
Phanindra_I
Phanindra
