We uses 'Murata Type 1LD' module which comes with pre-loaded Ayla Cloud Agent. We were wondering whether there is any way to reprogram the module to use a custom application built using Wiced SDK (and hence removing Ayla support). We do not have access to JTAG on this unit. We do have access to serial debug console. Any help on this is highly appreciated
regards
SR
AIROC™ Wi-Fi MCUs
I can see the programmer in the below link has support for UART bootloader. We haven't tested it on our end but you can consider evaluating it for your design.
(https://www.st.com/en/development-tools/stm32cubeprog.html)
Phanindra.
By default, the WICED build system makes use of OpenOCD scripts which would program using JTAG or FTDI. Which serial interface is being used in your design? Is it UART or SPI or some other interface?
We have access to UART serial interface only. Could you please let us know how we could use OpenOCD scripts to program Murata Type 1LD board without JTAG interface?
In the data sheet of Murata Type 1LD module, I can see pin no 18 to pin no 22 are JTAG pins. Can you clarify what do you mean by you don't have access to JTAG on the unit?
Phanindra
We know about the JTAG pins, it is not brought out from the PCB. Please note that we would have never asked this query had there is a way to access JTAG
regards
SR
You can build your custom application in WICED and you can consider using an external UART bootloader to program the *.elf and *.bin files that are generated as part of build process.
Phanindra.
Thanks for the reply. Exactly this is what we are also trying to do. Could you please let us know where we could get an external UART bootloader for Type 1LD? We couldn't find any option in WICED to build a custom bootloader for this purpose
regards
SR
Phanindra.
