Hello.
I'm using I2C on CYW954907EVAL1F as SMBUS
to comunicate with RRC2054: it is a smart battery.
The communication doesn't work.
I notice that I2C-DATA toggle when I2C-CLK has a falling edge:
does this lead to a misinterpretation at slave side ?
(E.g. can interpreted as I2C - START or I2C - STOP conditions ?)
Is there a way to configure the CYW954907EVAL1F microcontroller to force I2C-DATA to toggle when I2C-CLK is Low ?
- i2c
Hi @MaFa_974161 ,
I2C-DATA should toggle when I2C-CLK is Low by default. And you might not be able to change the data triggering method.
Are you reading or writing operation?
Are you communicating in which frequency?
Rakesh B G
I'm performing two operations:
the first is a write of 0x0D (Command Code for read "RelativeStateOfCharge") to a device wich address is 0x0B (0001 011 - Smart Battery).
The second is a two byte read (one word) to a device wich address is 0x0B (0001 011 - Smart Battery).
The two byte are the "RelativeStateOfCharge" word.
I' m working at 10kHz.
