We met problem on implement unqiue factory reset DCT
according "WICED-AN800-R-Factory-Programming.pdf" WICED-Studio6.6.1.1
copy factory_reset_dct.c; temp_control_dct.c .h; and mfg folder. detail see attachment
>make snip.apsta-CYW943907AEVAL1F download download_apps run It can success work.
make the unqiue DCT 001
>make snip.apsta-CYW943907AEVAL1F factory_reset_dct apps/snip/apsta/mfg/0001.txt
download it to DCT location 0x8000 .\tools\OpenOCD\Win32\openocd-all-brcm-libftdi.exe -s >.\tools\OpenOCD\scripts -f ./tools/OpenOCD/CYW9WCD1EVAL1.cfg -f ./tools/OpenOCD/BCM4390x.cfg -f apps/waf/sflash_write/sflash_write.tcl -c "sflash_write_file build/snip.apsta-CYW943907AEVAL1F/factory_reset/factory_reset_dct_0001.bin 0x00008000 CYW943907AEVAL1F-P103-SoC.43909 0 43909" -c shutdown >> build/openocd_log.txt 2>&1
Then reset the board. found the application can startup, but the DCT contect is incorrect. So where is my mistake? What is the correct step?
Thanks!
Max
If you are looking at having unique DCT's for applications, have a look at snip.dct_read_write and it might actually be easier than the way mentioned above. If above is not a suitable option, let us know and we can see what needs to be done.
