How to download test.mfg_test to CYW43907 RAM and run without SFLASH.
By this we can set the OTP data independently .
No need download mfg_test to SFLASH to set OTP and then download the product's apllication.
Set SECURE_BIT in OTP then replance the application FW in SFLASH, it's high risk.
Regards!
Max
ispn:36623:1:0
l1:3966:1:0
l2:6066:1:0
Hi @Max_Li ,
Thanks for contacting Infineon support. we are working on your query we will get back to you as soon as possible.
Rakesh B G
Hi @Max_Li ,
OTP programming require mfg_test firmware. If you are planning to enable secure bit, refer section "6.5 Enable Secure Bit" in the document for which link attached below.
Rakesh B G
Hi Rakesh,
Thanks for your reply!
Like the AN mentioned in 6.5:
"Download the target application. This must be done before step 4 (power cycle), otherwise the JTAG port will be disabled and the application download will not be possible. "
There is risky before we complete download the target application and after use wl in mfg.test set SECURE_BIT.
Because this, I expect download the target application first. Then use the wl run in RAM to set SECURE_BIT at last.
I think you can understand my concern.
Regards!
Max
Hi ,
Actually the suggested process compromises the devices security.
So the current steps are secured, even if it is risky if we miss doing the steps properly.
Rakesh B G
