- Email to a Friend
What is the proper way to add multiplexing capability for pins on CYW43907 radio module using ModusToolbox?
I believe I need to add a line in the file: mtb_shared/mtb-hal-cat4/release-v0.5.0/COMPONENT_CAT4/source/cyhal_pin_package.c that connects GPIO_23 to PIN_PWM_5 per table 13 in the CYW43907 datasheet Rev L. However, I don’t understand the format to add that line of code.
There’s currently only one line for PIN_PWM_5 in cyhal_pin_package.c at line 231 of {5, 0, PIN_PWM_5, PIN_MUX_SEL_1},
I want to add another line that allows a connection from GPIO_23 to PIN_PWM_5 via PIN_MUX_SEL_3.
What do the first two values in the line of code represent?
Here’s what I know of the format : {<some number_A>, <some_number_B>, <pin_name>, <mux input column from Table 13 of CYW43907 datasheet>},
Greg
AIROC™ Wi-Fi MCUs
- Email to a Friend
Hi @GrCa_1363456 ,
The format : {<The associated resource block number>, <The associated resource block's channel number>, <The GPIO pin>, <The pin function index value(mux input column from Table 13 of CYW43907 datasheet)>},
Rakesh B G
- Email to a Friend
Hi @GrCa_1363456 ,
Rakesh B G
