We are using 43909 WLAN Chip with HOST Variant BCM43907. We upgraded the Wiced firmware from 6.4 to 6.6 recently. After Wiced Upgradation we are facing an issue with Debug print not coming after WLAN is loaded.
Scenario:
1. Initially Debug print coming good.
2. Once WLAN Firmware is loaded. Debug print stop working or not coming on debug console.
Please suggest us how to figure out the issue.
__PRESENT
Hi @pavansrkote ,
Are you using your custom board ?
Have you verified your new code in evaluation kit?
Rakesh B G
Hi Rakesh,
Yes we are using custom board.
No we didn't verified with EVK.
But After Wiced Upgradation We tried with Old LAN Firmware(43909B0.bin). It's working fine. Only if we use the latest LAN Firmware(43909B0.bin) we are facing the issue. Also, some functionality we tested it's working fine. But only Debug print's not coming on console.
Pavan Kote
