Hello ,
I am trying to integrate laird LBW5+ (based on CY4373E cypress module) with imxrt117x -EVK over SDIO but getting following output can someone guide me in this??
CMD0
CMD5(no argument) response 01000011 111111111111100000000111
CMD5 (argument) ----timeout
CMD3 -----Failed to send command
Thanks in advance🙂
hello PRI,
thanks for reply,
we solved that problem it's due to some voltages missed by our team
We are developing our own driver with rtos and now we are facing new problem while extracting CIS information. we are not getting response from card and pointer value of pointer is 4268 .
do you have any idea on this??
Thanks🙂
I will check internally once and get back to you on this.
Can you let me know what is the driver that you are using? Is it WHD?
hello PRI,
thanks for reply,
Thanks🙂
Can you create another thread for the new issue? Also, describe the issue in detail like are you using the 4373 module in sdio form factor and plugging it into sd slot of the imx board. Just to confirm, you are developing the wifi driver right as mentioned in your previous reply?
