I'd like to use wiced_set_multi_advertisement_scan_response_data() on CYW43012. I see that the rest of the multi advertisement API is defined in beacon_util.c. Where can I find the implementation of wiced_set_multi_advertisement_scan_response_data()?
Hi @mogenson,
Kindly let us know whether you are using btsdk or btstack.
In btstack (hosted mode), the source code is kept hidden. Please give us some more details regarding why do you want to see the implementation of the API.
Advait Kulkarni
Hi @mogenson,
Advait Kulkarni
