How can I establish a communication between Termite 3.4 and the bluetooth application of my cell phone using the SPP Multi-Port Application library???
Hello @pablo
The instructions for testing the demo example is given in the Readme file along with the project.
Have you already tried those steps and facing any issues ? Please confirm.
Anjana
Hello @pablo
Anjana
yes, i followed all the instructions and i did not have any problem, but that i realy want to know is how could i suply BtSpay thith Termite 3.4???
thanks for all
If you want to know how to enable BTSpy in the application, please follow the instructions in the below blog. I believe most of the steps already done in the SPP application. You may just have to route the debug logs to appropriate UART wiced_set_debug_uart().
Please read the Readme of BtSpy for more info.
https://github.com/Infineon/btsdk-utils/tree/master/BTSpy
Please note, there are two SPP application. Please select the appropriate one for your requirement.
https://github.com/Infineon/mtb-example-btsdk-rfcomm-spp
https://github.com/Infineon/mtb-example-btsdk-rfcomm-spp-multi-port
-Dheeraj.P.K
