I am developing on CYBT-343026 with SPP on Modus. And there are two problems
1 . I can search and but can't connect to the eval board from my SPP藍芽串口 on Redmi K40
2 . I can receive log from HCI Uart but I can't receive anything from puart.
I just run the deafult sample code without any modification. What could be the problem.
By the way, my Modus is version 2.4
I could see similar disconnection issue when I tested the spp app on CYW920706WCDEVAL. I see some L2CAP disconnection. Our FW team will be fixing this issue in the upcoming SDK - BTSDK3.3.
If possible could you please share the logs collected at your side using btspy to confirm the issue?
-Dheeraj.P.K
Is this connection problem only when you use Redmi K40? Have you tried using any other peer device?
Please uncomment wiced_set_debug_uart( WICED_ROUTE_DEBUG_TO_PUART ); to route the logs to PUART.
-Dheeraj.P.K
I uncomment wiced_set_debug_uart( WICED_ROUTE_DEBUG_TO_PUART ), wiced_hal_puart_select_uart_pads( WICED_PUART_RXD, WICED_PUART_TXD, 0, 0) and comment wiced_set_debug_uart(WICED_ROUTE_DEBUG_TO_WICED_UART). Now the puart works, But the bt connection still failed. I have tried two different app on two different phones. And both of they can't connect to my eval board
I think this might be the problem
-Dheeraj.P.K
