I am unable to debug the CYBLE-343072-eval-m2b. How do I set the board up? SW8 does nothing. Makefile changes needed? I am using ModusToolbox 2.4 and the Hello Sensor example.
With MiniProg4 connected to J13
Error: DAP 'CYW20835B1.cpu' initialization failed (check connection, power, transport, DAP is enabled etc.)
With J-Link connected to J13
Listening on TCP/IP port 2331
Connecting to target...
ERROR: Could not connect to target.
Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
AIROC™ Bluetooth
Hi @geoffrey_moyer , The only change in the project that you need is to set "ENABLE_DEBUG" as 1 in the appication makefile
In makefile, you should see a variable "ENABLE_DEBUG", you need to set that to 1 as follows:
ENABLE_DEBUG?=1
I'm able to reproduce your issue if I don't set this variable to 1. See attached working and not working logs. I don't have cyble-343072-eval-m2b kit at the moment, so I tested with CYW920819EVB-02.
Bragadeesh
Please check section Debugging Via the Arm Debug Port in the following document
https://github.com/Infineon/CypressAcademy_BT101_Files/blob/master/PDFs/WBT101-05-Debugging.pdf
Also, AIROC-Hardware-Debugging document.
https://infineon.github.io/btsdk-docs/BT-SDK/AIROC-Hardware-Debugging.pdf
Bragadeesh
I am still having trouble and it must be something simple and frustrating.
The J-link and cable is set up properly because it debugs a PSOC 6 without any problems. However with the CYBLE-343072-EVAL-M2B it does not. It reports:
J-Link GDB Server failed:
Could not connect to target. Please check if target is powered and if ribbon cable is plugged properly.
For more details, see the JLinkGDBServerCL.exe console.
The console shows connection to the J-Link S/N ...224 but not the target.
Command line: -if swd -device Cortex-M4 -endian little -speed auto -port 2331 -swoport 2332 -telnetport 2333 -noreset -noir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
-----GDB Server start settings-----
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: off
Init regs on start: off
Silent mode: off
Single run mode: on
Target connection timeout: 0 ms
------J-Link related settings------
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
------Target related settings------
Target device: Cortex-M4
Target interface: SWD
Target interface speed: auto
Target endian: little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V10 compiled Apr 23 2020 16:49:14
Hardware: V10.10
S/N: 600114224
Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
Checking target voltage...
Target voltage: 3.28 V
Connecting to target...ERROR: Could not connect to target.
Shutting down...
Is there a CY_TOOL_PATHS requirement to get the J-link working? I have no setting for CY_TOOL_PATHS because I am using default locations.
The build has the DEBUG = 1, -DENABLE_DEBUG=1 and appears to be OK.
10:34:56 **** Build of configuration Debug for project LE_Hello_Sensor_343072M2B ****
"C:\\Users\\Geoff\\ModusToolbox\\tools_2.4\\modus-shell\\bin\\make" CY_MAKE_IDE=eclipse CY_MAKE_IDE_VERSION=2.4 CY_IDE_TOOLS_DIR=C:/Users/Geoff/ModusToolbox/tools_2.4 -j8 all
CYBLE-343072-EVAL-M2B.mk: ../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/CYBLE-343072-EVAL-M2B.mk
Log file= "C:/Users/Geoff/AppData/Local/Temp/device-configurator-cli/device-configurator-cli-20220131.103459.533-9416.log"
Command line= "C:/Users/Geoff/ModusToolbox/tools_2.4/device-configurator/device-configurator-cli.exe --library ../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/devicesupport.xml --build ../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/design.modus --check-mcu=CYBLE-343072-02 --check-coprocessors= --readonly --skip-build"
generated C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/Debug/BLE_HelloSensor.ld
Prebuild operations complete
Commencing build operations...
Initializing build: BLE_HelloSensor Debug CYBLE-343072-EVAL-M2B GCC_ARM
Auto-discovery in progress...
-> Found 22 .c file(s)
-> Found 0 .S file(s)
-> Found 0 .s file(s)
-> Found 0 .cpp file(s)
-> Found 0 .o file(s)
-> Found 13 .a file(s)
-> Found 141 .h file(s)
-> Found 0 .hpp file(s)
-> Found 0 resource file(s)
Applying filters...
Auto-discovery complete
Constructing build rules...
Build rules construction complete
= Building application =
Generating compilation database file...
-> ./build/compile_commands.json
Compilation database file generation complete
Generated 1 source file(s)
generated C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/generated/lib_installer.c
Building 10 file(s)
Compiling COMPONENT_btstack_v1/hello_sensor_gatt.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Compiling COMPONENT_btstack_v1/wiced_bt_cfg.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Compiling hello_sensor.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Compiling C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/generated/lib_installer.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Compiling ../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1/platforms/wiced_platform.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Compiling ../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common/spar_setup.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Compiling ../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource/cycfg.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Compiling ../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource/cycfg_pins.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Compiling ../mtb_shared/wiced_btsdk/dev-kit/libraries/btsdk-common/release-v3.2.0/factory_config_read.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Compiling ../mtb_shared/wiced_btsdk/dev-kit/libraries/btsdk-common/release-v3.2.0/wiced_bt_utils.c -DENABLE_DEBUG=1 -DWICED_BT_TRACE_ENABLE -DDEV_NAME=\"Hello\" -DWICED_HCI_TRANSPORT_UART=1 -DWICED_HCI_TRANSPORT_SPI=2 -DWICED_HCI_TRANSPORT=1 -DHCI_UART_MAX_BAUD=4000000 -DHCI_UART_DEFAULT_BAUD=3000000 -DKITPROG3_USE_2_STOP_BITS -DCY_PLATFORM_SWDCK=WICED_P02 -DCY_PLATFORM_SWDIO=WICED_P03 -DSS_LOCATION=0x0 -DVS_LOCATION=0x2000 -DDS_LOCATION=0x4000 -DDS2_LOCATION=0x42000 -DCYW20835B1=1 -DBCM20835B1=1 -DBCM20835=1 -DCYW20835=1 -DCHIP=20835 -DAPP_CHIP=20835 -DOTA_CHIP=20835 -DCHIP_REV_A_20835B1=1 -DCOMPILER_ARM -DSPAR_APP_SETUP=application_setup -D__TARGET_CPU_CORTEX_M4 -D__ARMCC_VERSION=400677 -DPLATFORM='"CYBLE_343072_EVAL_M2B"' -DCYBLE_343072_EVAL_M2B -DCY_PATCH_ENTRIES_BASE=122 -DWICED_SDK_MAJOR_VER=3 -DWICED_SDK_MINOR_VER=2 -DWICED_SDK_REV_NUMBER=0 -DWICED_SDK_BUILD_NUMBER=20467 -DSPAR_CRT_SETUP=spar_crt_setup -DCOMPONENT_20835B1 -DCOMPONENT_SOFTFP -DCOMPONENT_bsp_design_modus -DCOMPONENT_btstack_v1 -DCY_SUPPORTS_DEVICE_VALIDATION -DCYBLE_343072_02 -I. -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/COMPONENT_20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/WICED/common -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/arm/cmsis -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/hal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/include/stack -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal -I../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/internal/20835B1 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0 -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus -I../mtb_shared/wiced_btsdk/dev-kit/bsp/TARGET_CYBLE-343072-EVAL-M2B/release-v3.2.0/COMPONENT_bsp_design_modus/GeneratedSource -I../mtb_shared/wiced_btsdk/dev-kit/btsdk-include/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0 -I../mtb_shared/wiced_btsdk/tools/btsdk-host-apps-bt-ble/release-v3.2.0/include -I./COMPONENT_btstack_v1
Linking output file BLE_HelloSensor.elf
Begin post build processing
Patch code starts at 0x270400 (RAM address)
Patch code ends at 0x275ACC (RAM address)
Patch ram starts at 0x20FF2C (RAM address)
Patch ram ends at 0x2100D0 (RAM address)
Application memory usage:
.text SRAM start 0x2100D0, end 0x210C7A, size 2986
.rodata SRAM start 0x210C7C, end 0x2114BE, size 2114
.data SRAM start 0x2114C0, end 0x211534, size 116
.bss SRAM start 0x211534, end 0x21164C, size 280
.setup SRAM start 0x21164C, end 0x2116BC, size 112
Battery backed RAM start 0x28386C, end 0x28386C, size 0
ram (SRAM): used 0x2100D0 - 0x2116BC size (5612)
Total application footprint 5612 (0x15EC)
DS available 253952 (0x03E000) at 0x004000
generate hex file:
cgs -D C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/Debug -A 0xFF000000 -O DLConfigBD_ADDRBase:20835B1746DF -B ../mtb_shared/wiced_btsdk/dev-kit/baselib/20835B1/release-v3.2.0/COMPONENT_20835B1/platforms/20835_SFLASH.btp -P 0x00000000 -I C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/Debug/BLE_HelloSensor_download.hex -H C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/Debug/BLE_HelloSensor_download.hcd -M C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/Debug/BLE_HelloSensor.cgs.map --cgs-files C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/Debug/BLE_HelloSensor.cgs
cgs v1.6.0.0003 20170419
Processing cgs files:
Creating Intel Hex file: C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/Debug/BLE_HelloSensor_download.hex... succeeded
Creating HCD file: C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/Debug/BLE_HelloSensor_download.hcd... succeeded
Creating map file: C:/Users/Geoff/mtw/LE_Hello_Sensor_343072M2B/build/CYBLE-343072-EVAL-M2B/Debug/BLE_HelloSensor.cgs.map... succeeded
Post build processing completed
= Build complete =
10:35:07 Build Finished. 0 errors, 0 warnings. (took 10s.409ms)
with a miniprog4 debugging fails:
Info : KitProg3: FW version: 2.30.1155
Info : KitProg3: Pipelined transfers enabled
Info : VTarget = 3.304 V
Info : clock speed 10000 kHz
Error: Error connecting DP: cannot read IDR
Info : CYW20835B1.dap: powering down debug domain...
Error: Error connecting DP: cannot read IDRW
arn : Failed to power down Debug Domains
The debug build looks OK to me.
Still a problem. Is the clock too high - info clock speed 10000 kHz? How to change it? How to check DAP, transport, connections? Following the instructions for miniprog "Hardware debugging for AIROC™ Bluetooth® SOC" gets the same errors.
<install dir>\tools_2.4\openocd\bin\openocd -s <install dir>\tools_2.4\openocd\scripts -s <workspace dir>\mtb_shared\wiced_btsdk\dev-kit\baselib\20835B1\release-v3.2.0\COMPONENT_20835B1\platforms -f CYW20835B1_openocd.cfg
Open On-Chip Debugger 0.11.0+dev-4.3.0.1746 (2021-09-16-07:59)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
adapter speed: 10000 kHz
Info : auto-selecting first available session transport "swd". To override use 'transport select <transport>'.
cortex_m reset_config sysresetreq
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : Using CMSIS-DAPv2 interface with VID:PID=0x04b4:0xf151, serial=0F2204B803260400
Info : CMSIS-DAP: SWD supported
Info : CMSIS-DAP: JTAG supported
Info : CMSIS-DAP: Atomic commands supported
Info : CMSIS-DAP: FW Version = 2.0.0
Info : CMSIS-DAP: Interface Initialised (SWD)
Info : SWCLK/TCK = 1 SWDIO/TMS = 1 TDI = 0 TDO = 0 nTRST = 0 nRESET = 1
Info : CMSIS-DAP: Interface ready
Info : VTarget = 3.303 V
Warn : Failed to power down Debug Domains
ENABLE_DEBUG?=1
Bragadeesh
