Hi Sir
My customer uses 20719+icofchina's AT2401C solution, which sdk can be used to test rf?
Hello @CYW20719
I guess for RF tests, you can download an empty application from our latest SDK and use CyBluetool or WMBT tools to issue the RF test commands.
Anjana
Hello @CYW20719
For RF test, you can either use CyBluetool or wmbt available in MTB IDE.
Please refer this page for more details: https://community.infineon.com/t5/Resource-Library/Module-Partner-Ecosystem-Tools-for-Getting-to-Pro...
Anjana
Hi
I wonder if this code RFCOMM_Serial_Port can be used to test rf based on this scheme?
Hello @CYW20719
Anjana
