cyw20706 transport uart receive delay
maze_1672671
First like received 25 replies posted 25 sign-ins
Hello all,
we are using the transport uart in WICED_TRANSPORT_UART_RAW_MODE
This happens when sending a custom echo command:
Between the end of the rx (2nd row, A1) and the call to p_data_handler (3rd row, A2) there are 15.6 ms
B1 marks the end of the echo (1st row), so it takes 19.4 ms to send the command and receive the echo but 15.6/19.4=80% of the time is spent doing nothing!
How can we reduce that delay?
maze_1672671
my fault: I forgot to add wiced_transport_free_buffer
Owen_Zhang123
5 questions asked 500 solutions authored 250 sign-ins
Is there any other active events during the test? The receive event may be delayed by other events such as BLT/BT events.
maze_1672671
no, it is a central but it is not connected and it is not searching
Could you test the HCI Mode instead of the HCI RAW Mode?
The raw mode is rarely used and I am not sure if there is some bugs with it.
maze_1672671
how can I do this with the minimal effort?
maze_1672671
now it is fast but in less than 100 echoes it stops working
I must power off the eva board and program it again
maze_1672671
