create new application using ModusToolbox 3.0 failure
Bill_123
Level 4
Level 4
Distributor - Weikeng(GC)
50 replies posted 100 sign-ins First like received
Dear IFX,
I create new application using ModusToolbox 3.0 failure.
fail log:
ERROR:make: *** [../mtb_shared/core-make/release-v1.9.1/make/core/main.mk:434: secondstage_build] Error 2
ERROR:Failed to export the "LE_Beacon_1" application to Eclipse IDE for ModusToolbox™.
B.R.
Bill.
Hi @Bill_123 ,
In your control panel, search for environment variables>edit environment variables>system variables>new>add the name (CYREMOTE.... as shown in that article you shared) of new variable and value>save.
Thanks and regards,
Advait Kulkarni
advait_kulkarni
25 likes received 250 sign-ins 100 solutions authored
Hi @Bill_123 ,
Can you try creating a new workspace (make sure it is in MTB 3.0 only) and import this project there? Also please try with a different code example and let me know if you are facing the same issue with that as well.
Thanks and regards,
Advait Kulkarni
Bill_123
Level 4
Level 4
Dear @advait_kulkarni,
What is mean "make sure it is in MTB 3.0 only"?
Do you mean clean files in mtw folder?
I have cleaned files in mtw folder and then create new project by "New Application",but the fail state still appear.
BTW, I have tried another code the,fail state is still exist .
B.R.
Bill.
advait_kulkarni
Hi @Bill_123 ,
Try "make getlibs" command in the CLI terminal and do it again. Also, do you have the CYremote manifest variable setup in the environment variables? If not,go to env variables>system variables, create a new variable "CyRemoteManifestOverride" and give the value as https://github.com/Infineon/mtb-super-manifest/blob/v2.X/mtb-super-manifest-fv2.xml
After this, try creating again and let me know if it works.
Thanks and regards,
Advait Kulkarni
Bill_123
Level 4
Level 4
Could you guide us about where "Edit system variables" is?
We find below information as below but he didn't say where "Edit system variables" on ModusToolbox 3.0 is .
https://community.infineon.com/t5/Knowledge-Base-Articles/Offloading-the-Manifest-Files-of-ModusTool...
B.R.
Bill.
Hi @Bill_123 ,
Thanks and regards,
Advait Kulkarni
