sorry for the stupid question but this is my first time with Cypress ecosystem and also I'm not a professional firmware developer.
When I use ModusToolbox, the available template projects don't include the Audio Sink app, but the project README (https://github.com/cypresssemiconductorco/mtb-example-btsdk-audio-a2dp-sink) has a section named "List of boards available for use with BTSDK", which includes my eval board.
My understanding is that the board is compatible with the btsdk, that means I have access to functions like "wiced_audio_sink_configure" (https://cypresssemiconductorco.github.io/btsdk-docs/BT-SDK/20706-A2_Bluetooth/API/group__wicedbt__a2... that allow me to configure and eventually use the audio functionality of the chip, but the example project for some reason is not compatible with it.
Am I correct? Can somebody help? Many thanks, Davide
PSoC general
Make sure you have correct device as active in Library manager. You can refer Library Manager user guide here- https://www.cypress.com/file/520271/download
Hi @davethecipo ,
No question is stupid if you are learning new thing.! 🙂
Can you please send the screenshot of error you are facing? Install latest ModusToolbox from https://www.cypress.com/products/modustoolbox
They follow the procedure mentioned in audio sink readme file. You can also try programming a basic application like LE Hello Sensor and check if your module board is working fine.
the board works because I tried the GPIO and ADC example projects. If I modify the Makefile by adding CYBT-343026-EVAL to the supported targets and to the TARGET line, then I get
11:15:16 **** Build of configuration Debug for project Audio_Sink ****
"C:\\Users\\dolia\\ModusToolbox\\tools_2.3\\modus-shell\\bin\\make" CY_MAKE_IDE=eclipse CY_MAKE_IDE_VERSION=2.3 CY_IDE_TOOLS_DIR=C:/Users/dolia/ModusToolbox/tools_2.3 -j12 all
C:/Users/dolia/ModusToolbox/tools_2.3/make/startex.mk:380: *** Build support for the target device not found. Run "make getlibs" to ensure all required build and code dependencies are present.. Stop.
"C:/Users/dolia/ModusToolbox/tools_2.3/modus-shell/bin/make CY_MAKE_IDE=eclipse CY_MAKE_IDE_VERSION=2.3 CY_IDE_TOOLS_DIR=C:/Users/dolia/ModusToolbox/tools_2.3 -j12 all" terminated with exit code 2. Build might be incomplete.
11:15:17 Build Failed. 1 errors, 0 warnings. (took 1s.0ms)
If I then run "make getlibs" from the shell, I get
$ make getlibs
= Importing libraries =
Git is git version 2.17.0, found at /usr/bin/git
Resolving dependencies...
Checking if remote manifest is accessible...
QNetworkReplyHttpImplPrivate::_q_startOperation was called more than once QUrl("https://github.com/cypresssemiconductorco/mtb-super-manifest/raw/v2.X/mtb-super-manifest-fv2.xml")
Processing super-manifest https://github.com/cypresssemiconductorco/mtb-super-manifest/raw/v2.X/mtb-super-manifest-fv2.xml...
Successfully acquired the information.
Warning: Unable to find the Active BSP in the manifest database.
Nothing to update.
Dependencies resolved.
Searching application directory (.mtb)...
Found 5 .mtb file(s)
Processing file "C:/Users/davide/mtw/Audio_Sink/deps/btsdk-audio.mtb"
Processing file "C:/Users/davide/mtw/Audio_Sink/deps/btsdk-host-apps-bt-ble.mtb"
Processing file "C:/Users/davide/mtw/Audio_Sink/deps/btsdk-ota.mtb"
Processing file "C:/Users/davide/mtw/Audio_Sink/deps/btsdk-peer-apps-ota.mtb"
Processing file "C:/Users/davide/mtw/Audio_Sink/deps/TARGET_CYW920706WCDEVAL.mtb"
Libraries processed.
Created file "C:/Users/davide/mtw/Audio_Sink/libs/mtb.mk".
= Import complete =
Then I run "make build" again, but I get the first error. I am left to think that the code example is not compatible. I will get familiar with the board using other exaples.
Thanks again, Davide
OMG this was the problem! Thanks I can see the wiced app from my smartphone now! Best regards, Davide
