Actually, we work with CYBT-213043-02 to make an application using the mesh stack. We use an embeded provisionner to provision the nodes.
Is there any documentation about the flash mapping where the network information is stored ?
Hwo do we program static data such UUID during production ? is there any advice ?
Thank you for your answer
- CYBT-213043-MESH-02
Unfortunately, there is no such document that explains flash mappings. Usually, UUID should be unique and randomly generated. For testing and qualification purposes, you can configure a hardcoded id as well. For that please check mesh_application.c. (mesh_application_init())
-Dheeraj.P.K
-Dheeraj.P.K
